Nest 7 inch nest hub setup problem, link account
DougH
I am trying to setup a 2nd nest hub (new unit as of February, 23).  I am able to connect to my WiFi network (Eero Pro6) and the hub updates itself and all steps in the Home app are followed (latest updated home version).  The hub then displays a message to link account and tells me to open the home app, which is already open to do the setup.  In the app, I find nothing about linking an account.  I have done all of the above several times, including doing a factory reset on the hub and checking the latest software version and recycling the Eero.  I finally called the Best Buy Geek Squad and there tech ran into the same dead end.
I see MANY inquiries about this issue going back a couple years.  One would think Google would be all over this matter.
Juni
Hi DougH,
Thanks for reaching out and for providing detailed information on your issue and the steps that you've done — these are of great help!
Could you try to check these router settings and after you adjust your router, set up your Nest Hub again and observe if it will make a difference?
  • Enable: Universal Plug and Play (UPnP), multicast, Internet Group Management Protocol (IGMP)
  • Disable: AP / client isolation, virtual private networks (VPNs), proxy servers, IGMP Proxy. VPNs and proxy servers should be disabled on your computer as well (if applicable).
  • Change DNS addresses: 8.8.8.8 and 8.8.4.4
  • If IPv6 is enabled, try disabling it for the meantime
Juni
Juni
I just wanted to follow up if you were able to try the steps provided. Please let us know as we would be happy to answer any questions you may have.
Juni
Muddi
Hey DougH,
Just bumping this up to make sure that you've seen our responses. I'll lock this thread if we won't hear from you in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Muddi
