09-12-2022 11:34 AM
I cannot connect any devices to my Hub Max. How do I put it into Pairing Mode?
09-12-2022 12:06 PM
Select your Nest Hub Max in the Google Home app, then select Settings | Audio | Paired Bluetooth devices, and then select "Enable Pairing Mode" in the bottom right corner of the screen.
https://support.google.com/googlenest/answer/7381505?hl=en#zippy=%2Cfrom-the-google-home-app
09-17-2022 12:02 PM
MplsCustomer, thanks for the help.
TCat, did the shared information by MplsCustomer help? Could you tell us more about what devices you're trying to connect to your Google Nest Hub Max?
Alex
09-20-2022 12:15 PM
Hi TCat,
Alex
09-21-2022 12:17 PM
Hello TCat,
I haven't heard from you in a while so I'll be locking this thread in 24 hours. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the Community.
Alex
