Nest Hub Max Not Showing Photos
DanDryfhout
I have followed the suggestions of creating an album in Google photos and adding it in the settings on my Google Home app. One I select any album, it previews the image but my Nest Hub Max continues to show the art gallery photos instead. Any help?
Princesss
Hi DanDryfhout,
Thanks for reaching out.
If you have successfully added your photos on your Google Photos account, you can now view these photos on your Google Nest Hub Max as long as you're using the same Gmail account that you're using both on Google Photos and Google Home. To check these settings, you can follow these steps:
Google Home app:
  1. Open the Google Home app .
  2. Touch and hold your device's tile.
  3. At the top right, tap Settings and then Photo Frame and then adjust the settings you want.
    You can add or remove albums with the Home app or your Nest display.
Home app:
  1. Open the Home app .
  3. Tap Settings and then Photo Frame and then Google Photos.
  4. Select albums to add and deselect albums to remove.
Hope this helps.
Princess
Princesss
Hi DanDryfhout,
Chiming in to check if you still need help with this? I hope that the steps I provided worked.
If you still need assistance, feel free to respond to this thread so we can assist you further.
Princess
Thanks Princess!
This helped me out!
Princesss
Hi DanDryfhout,
Thanks for the update. Glad to know that it worked!
For now, since this has been resolved, I'll go ahead and close this thread from further discussion to keep our community tidy. Feel free to start a new thread anytime you need help with your Google Nest speakers and don't forget to add more details so others can lend a hand.
Princess
