01-16-2024 11:20 PM
Today, my Nest Hub Max started to show a solid white screen.
I have tried the following fixes:
Rebooted (several times), and it went to the G logo on a white screen. It never got any further in the startup process
Factory reset, and was able to start the setup up process. Got to the last screen where it has a button saying Finsh Setup on the Google Nest Max. The Hub then went to a white screen. The Google Home app is stuck on a screen saying Configuring your Nest Hub Max.
On the Nest Hub Max, pressing volume keys will raise or lower the volume, and show the volume indicators on screen. Swiping up does nothing. Nor swiping any other direction. Switching camera off displays the camera off message at the top of the screen.
From my searches it appears many others have had this problem, but none of the solutions are working.
What else can I try, or is it time for a replacement?
01-20-2024 04:09 AM
Hello BrokenNestHub,
We appreciate all your efforts. We'd like to take a deeper look into this for you. Please fill out this form with all the needed information, and then let us know once you're done.
Alex
01-20-2024 07:48 AM
I have spoken with phone support in the meantime. As soon as they knew how old my hub was, they said that there was nothing they could do because it was out of warranty. My options were to find a 3rd party repair shop (which does not exist where I live), or throw out the unit.
Luckily, I had not followed up on their suggestions right away. Sometime overnight, the Nest Hub Max fixed itself, and was working about 36 hours after it first went to a white screen.
I am not very impressed with the phone support when they recommend a costly fix, or to throw out a unit that appears to have had a non hardware related issue.
To sum up, it is working again.
01-23-2024 10:01 AM
It’s good to know that your Google Nest Hub Max is now working.
We'll definitely take this as feedback, and we'll ensure that we learn from it to be able to deliver a better experience in the future. Please let me know if I can help you with anything else on Google Home.
Alex
