09-07-2022 05:20 AM
My camera is no longer available on my display. I did a factory reset, reset my phones network settings, my router was reset, tried all the methods on an Android, and Iphone. Nothing is helping. I can not set it up. I had it for a year with no problems and with the Fusia update it will not work. I bought it for all it does including the camera so I can check in on my house when away. Any updates in the future that may fix this software glitch?
09-07-2022 11:41 PM
Hey Robcam,
I know how challenging it can be when you're having issues setting up your Google Nest Hub Max camera. A few questions: when did the issue start? Do you have other Nest devices (security camera, doorbell, thermostat)? What message are you getting when you set it up?
Please try these steps below:
Let me know if that works.
Muddi
09-10-2022 03:44 PM
I have 2 nest hub max, doorbell, and 3 cameras in addition to 2 new nest hub max with this same issue. What happens with the existing devices when I move 1 or 2 nest hub max to new home structure?
09-10-2022 04:26 PM
Hey TN52,
Thanks for that information. Once the setup is successful, you can move your existing devices on the new home structure. By the way, do you have a Nest subscription?
Muddi
09-12-2022 07:28 AM
Muddi, is there any way to access the cameras on the 2 new Hubs without creating a new Home and moving everything?
09-12-2022 09:16 PM
Hi TN52,
Please note that all your devices should be on one home structure for you to access or stream it on the Nest Hub Max.
Muddi
09-15-2022 10:12 PM
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions, otherwise we’ll be locking the thread.
Princess
09-16-2022 11:58 PM
Hello there,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google speakers and we'd be glad to assist you further.
Princess
