Nest Hub gen 2, bricked after less than 12 months after buying it
Johnfrancis24
Bought a Nest Hub Gen 2 about a year ago. Very Very little use. Suffered connection problems after a update. Factory reset only made the problem worse, first getting stuck finalising setup settings. Now after another reset, it won't even connect to my internet connection so I can't get past the first part of the setup settings. Did I really waste money only for Google to break it.
maedacortez
Hi Johnfrancis24,
Thanks for reaching out. I understand that your Nest Hub gen 2 can't connect to Wi-Fi. I know this can be frustrating, but don't worry, I'm here to help! To better understand your situation, I need to ask some questions.
  • What is the firmware version of your device?
  • Are there other Google Nest displays set up and working in the home?
  • Are you unable to find your Wi-Fi network when setting up your device?
  • Are you stuck or do you see an error message on your screen?
I'll be waiting for your response.
Manuel
  • Firmware version: Don't know.
  • No
  • I can find my Wi-Fi however it won't connect (it says the Wi-Fi network name and/or password is wrong) but everything is correct.
  • No errors message
Hi Johnfrancis24,
Thanks for replying. Based on your response, please try these steps:
Reboot the Wi-Fi router:
  1. Unplug the Wi-Fi router from the power source for 2 minutes.
  2. Ensure that the router's lights turn off completely when unplugged.
  3. After 2 minutes, plug the router back into its power source.
  4. Once all the router lights are back on, try to connect your Nest Hub 2 to your Wi-Fi. If this doesn't work, please try the next step.
From the Google Home app:
  1. Open the Google Home app.
  2. Select the speaker or display and then Settings.
  3. At the top right, tap More and then Reboot.
  4. Try to connect to Wi-Fi again. If this doesn't work, perform a reset.
Reset the device:
  1. At the back of the device, press and hold (long press) both volume buttons for about 10 seconds.
  2. Google Assistant will play a sound to signal the start of the factory reset process.
I hope this helps! Let me know if you have any other questions.
Manuel
Manuel,
I have tried everything mentioned above (several times) and nothing fixes the problem.
John
Hi Johnfrancis24,
Thanks for trying the troubleshooting steps. The next step is to send a feedback report. Here are the steps:
From the device:
  • Instruct the customer to say, “Hey Google, send feedback.”
  • The device will transcribe the audio feedback you provide and send the transcription to the Google Nest team. The audio of your feedback will not be recorded.
  • When finished, tap Send.
  • Open the Google Home app.
  • At the top right, tap the account icon.
  • Tap Feedback, then tap the device you want to submit feedback for.
  • To display available emails, tap the arrow on the right in the From section. Select the email address.
  • In the feedback summary, write a brief description of the issue.
  • Be sure to check the box for Screenshot and System logs.
  • To submit feedback, tap Send at the top right.
Manuel
