02-07-2023 05:59 PM
Were to even begin, I see all 3 on my Google home app, but that's about as good as it gets!
Nest mini..... "usually" works when I say "hey Google" (turn on my bedroom light, for example). But never works when I try to cast audio from my phone, immediately after hitting cast audio, I get a window that says casting stopped. It also does NOT do / say anything when the doorbell rings.
Nest display...... lets keep it simple..... ONLY the built in camera works! I cannot cast anything from my phone, can't see my doorbell. "Hey google" is immediately followed by either "something went wrong" or "there seems to be a glitch". Basically it's just taking up counter space.
Nest doorbell..... aside from not displaying on the nest display or sounding on nest mini, it seems to be the ONLY thing that works correctly.
As mentioned earlier, all 3 show on the home app. Went through every setting and set accordingly to get notifications etc etc.
Asking here is my last effort after trying everything for the 2 months I've lived here.
02-13-2023 11:29 AM
Hi Corvettejoez06,
This is not the experience we wanted you to have, let me help you. A few things: When did your issue begin? Were there any recent changes made? What music app or services are you not able to cast from? Does it happen every time? It would help a lot if you could do a sequential reboot first:
Looking forward to your responses.
Dan
02-13-2023 11:38 AM
Every issue I mentioned has been going on since I moved into my new house in December.
NOTHING
streams, music (amazon or even
files on my phone), or you tube.
And obviously in 2 months ive unplugged, restarted everything 100s of times trying everything. This was my last hope here!
02-20-2023 06:34 PM
Still nothing works correctly..... I'm at a loss and don't know where to turn.
02-28-2023 10:11 PM
Hey Corvettejoez06,
Apologize for the delays. Chiming in to ensure everything is covered here. To confirm, how far are your devices from your router? Please make sure that the mobile data is off on your phone/tablet to be able to cast on your Google Nest Hub and Mini device. If it still doesn't work, please reset your Nest Hub and Mini to refresh all the settings on your devices. Please note that resetting it will erase all the settings on your device.
Follow the steps below or visit this link for more steps on how to reset your devices:
Keep us posted.
Muddi
03-04-2023 12:27 PM
I'm jumping in to follow up if everything is good here. Let us know if you have any further questions.
Juni
03-04-2023 04:19 PM
03-04-2023 05:32 PM
Hi Corvettejoez06,
For confirmation, have you tried the steps above especially the factory reset? Doing so should revert your Nest devices back to its default and original settings. Afterwards, you set it back up and start fresh.
Dan
03-04-2023 05:40 PM
100 times.
This came with my brand new built house. moved in Dec 2022. There are 15 others in my neighborhood with the exact same problem. My builder (classic homes) is going to drop the Google smart home package and switch us all to Amazon if there isn't a fix soon.
03-07-2023 04:48 PM
Hi Corvettejoez06,
I appreciate you taking the time to do the steps needed. Since 15 others in the neighborhood have the same concern, it would seem we also need to check the Wi-Fi connection. Let’s start here to isolate further.
To eliminate network issues, please try setting up one of your devices using a mobile hotspot. Please note that you will need two mobile devices for this setup (one will serve as a router and the other to be used to set up your Google Home/Nest devices). Once done, check if your device will have the same behavior.
Dan
03-07-2023 04:55 PM
I did even one better (I'm a nerd like that)
I used my phone hotspot and a router that can bridge it. Connected my phone to that router then connected that router to my existing network..... and everything came alive! The ISP is blaming Google for the "coding" error...... next week all 15 of us will be getting switched to alexa (which works fine with the same ISP) IF THIS ISNT FIXED
03-08-2023 10:06 AM
I understand how you feel. Since you're able to access your router settings, let's go ahead and check some settings and do some slight changes to ensure a strong link between all your devices and your modem/router:
Let me know how it goes.
Dan
03-08-2023 10:18 AM
This is obviously way beyond your level of expertise since you seem to not even understand what I said that I did to make it work....
I replaced my ISPs modem with a different ISP and then it worked.... THE REST OF MY HOME NETWORK STAYED THE SAME!!!!!!!! AKA ROUTER AND WIRELESS DEVICES.
So telling me to check my router is worthless.... BECAUSE IT IS THE SAME.....
AND AGAIN..... EVERY NEW HOUSE IN MY NEIGHBORHOOD HAS THIS SAME PROBLEM.....
There is something in the coding between Google and my ISP that does not work (Forcebroadband).
03-08-2023 10:45 AM
Let me make it even MORE clear..... 2 separate devices.... THIS DOES NOT WORK
1) ISP MODEM (forcebroadband)
2) WIRELESS ROUTER(S) SAME AS BELOW
Let me make it even MORE clear..... 2 seperate devices.... THIS DOES........ WORK
1) ISP MODEM (T-Mobile)
2) WIRELESS ROUTER(S) SAME AS ABOVE CHANGED NOTHING AT ALL
03-14-2023 05:30 PM
Apologies for the delayed response. We appreciate all your efforts. We'd be happy to take a look into this for you. Please fill out this form with all the needed information then let me know once done.
Dan
03-14-2023 05:36 PM
Done....
That was stupid and a waste of time...
It was a form and all it said was describe your issues... aka what I've wasted a month doing here....
03-18-2023 12:32 PM
Hi Corvettejoez06,
Apologies for the inconvenience. We also got your form — thanks for filling it out. Our team will contact you via email soon. Please continue the conversation there as this thread will be locked after 24 hours.
Kind regards,
Dan
