06-14-2025 01:15 PM
My nest mini, after years of working perfectly fine, has today disconnected itself from my wifi and refuses to reconnect.
I have tried:
- unplugging my mini for a 30-count
- unplugging my router for a 30-count
- checking that my Google Home is up to date
- factory resetting my mini
- hard restart of Google Home
- uninstalling / reinstalling Google Home
- connecting my phone's wifi to the mini itself and trying to connect to my wifi
- bringing my mini even closer to my router, despite it being only 10ft away from it
and literally nothing has worked. Someone please help?
06-17-2025 07:08 PM
Hi Leef,
Thanks for reaching out to the community! I understand your Google Nest Mini has disconnected from your WiFi and won't reconnect again. I appreciate you for performing some troubleshooting steps to reconnect it. I'll be glad to help you with this!
To find the best solution, I'd like to ask the following:
Please keep me posted. I look forward to your response.
Juan
06-20-2025 01:27 AM
Thank you I'll try this after work today!
06-20-2025 01:34 AM
No wifi network changes and the error message I've been getting after the reset was "Nest Audio couldn't connect to x, check your input" but I entered my wifi password correct, I double checked and copied it right off my PC
06-22-2025 03:54 AM
Just followed that link and yes, my Google Home app is fully updated.
06-23-2025 05:56 PM
Hi Leef,
Thanks for keeping me updated! Let's continue addressing this inconvenience. I have some more questions for you:
Juan
06-24-2025 02:54 PM
it's just a standard home wifi, nothing special but it *is* shared with the rest of my family and yes, my computer and phone and xbox are all able to connect easily as always, however I never have both my pc and any of my gaming consoles on at the same time, if my pc is on then nothing else is and vice-versa.
06-25-2025 03:58 PM
Hi Leef,
Thanks for getting back to me with this information. Let's try the following troubleshooting steps to isolate the root cause of this inconvenience:
Tip: Some routers have backup battery packs, so you need to disconnect the battery packs as well to ensure that the router is completely turned off.
Please let me know how it goes. I look forward to your response.
Sincerely,
Juan
06-30-2025 12:45 PM
I'll give this a shot but it's going to take me a few days to find a moment where turning the internet off won't inconvenience the others I live with, I'll get back to you with the results as soon as I can!
07-05-2025 12:03 PM
I've done some thinking and thank you for trying to help but I think I'm going to give up on fixing whatever's wrong. I'll just put it in my closet and forget about it.
