Nest hub 2nd generation missing setting
tamirzitman
Hi, im missing out some crucial configurations as sleep sensing and the motion sense also.
Is this because I'm based in Israel? If so, why is that blocked and when it is expected to be released? I would probably not buy the product if I would know it will be limited.
Thank you
11 REPLIES 11
Celsomosquera
I have the same problem. I’m based in Venezuela
Геннадий
Я живу в Украине у меня тоже самое что и у вас.  Но датчики работают . как я проверил - поставил таймер . и по при приближению к хабу цифры  уменьшались . а при отдалении увеличивались . я думаю что наверное нужно поиграться с регионами. Мое мнение.
did you manage to configure it so it would work for you in Ukraine?
Hey all,
I wanted to check in and see if you are still in need of any help? Please let me know, as I would be happy to assist.
Hello Jake,
I continue with the same problem, I can’t  use the sleep sensor and the sensor doesn’t appear in the configuration options
The same
tamirzitman
Hi Jake,
yes.
the issue is yet to be resolved.
please help with it.
Giliraanan
Hi Jake, yes, still waiting for resolution.... Seems like sleep sensing at nest hub is disabled in Israel.
Azarco
Hi Everyone,
Sleep Sensing isn't currently available in all languages or countries. Our team is always looking forward to bringing more features to different regions — you can file a feedback report on the Nest Hub device. If you have additional questions, feel free to submit another post and provide as many details as possible so that others can lend a hand. Hope this helps!
Alex
Giliraanan
Hintamir, did you manage to resolv? I have the same issue
tamirzitman
no, still waiting for Google to reply to our concern...
