01-25-2023 04:19 PM
My nest hub when playing Netflix will always play the first episode of any show and then sticks on 25% and says having trouble playing this title.
I have tried hard reset relinking Netflix and even casting from phone(same error)
Only way to fix it is reboot and then it will work 75% of time. The other 25% needs a second restart.
Wifi signal is strong.
Any ideas?
Tia
01-31-2023 12:54 PM
Hi S0130972,
This is not the experience that we wanted you to have, let me help you out. When did your issue begin? Were there any recent changes made before the issue started? What is the distance between your Nest Hub and your Wi-Fi router?
Try to move your Nest Hub near your router and observe if this will make a difference. If the issue remains, try to set up your Nest Hub to a different network and check if it will stream continuously. Check the instructions below.
If your speaker or display is connected to an existing Wi-Fi network, but you'd like to connect it to a new one, follow the steps below:
If you get an error message that says "could not communicate with your [device]" when you try to forget your network, or the steps above don't work, you'll need to factory reset your device and set it up again.
Juni
02-03-2023 01:36 PM
It's me again. I want to make sure you're all good — how did the steps go?
Juni
02-03-2023 01:39 PM
Thanks Juni I performed the tests and placed a wifi extender near the display. Last night it worked well so 🤞🏻 it will work again tonight. Thanks for your help again
02-03-2023 01:53 PM
That's great. I'll keep this open for 24 hours. Feel free to update this thread if you need further help.
Juni
02-04-2023 06:47 PM
Good evening thanks for your help unfortunately it only lasted till today and again cannot play Netflix
02-08-2023 01:20 PM
Thanks for getting back to us and for trying those troubleshooting steps. Let's rule out the possibility that it has anything to do with the network. Set up your Nest Hub using a mobile hotspot. You need two phones for this. Follow the steps below.
Keep me posted.
Juni
02-11-2023 01:29 PM
I just wanted to follow up if you were able to try the steps provided. Please let us know as we would be happy to answer any questions you may have.
Juni
02-11-2023 03:56 PM
Thanks Juni, I did try and had same problem but I have decided to just give up on it and use a different solution. I really appreciate your help
02-12-2023 09:44 AM
Hey S0130972,
We understand and we appreciate your efforts. If you need our help with your Google Nest devices in the future, feel free to create a new thread and the Community would be glad to assist you.
In the meantime, we'll mark this as complete and lock this thread if we don't hear back from you after 24 hours.
Alex
