11-29-2022 01:08 PM
My nest hub constantly drops radio stations especially bbc radio 4 or bbc radio 3 the other google devices in the house do not have this problem
12-03-2022 01:43 PM
Hi Richardmn,
I'm sorry to hear that out of your multiple Nest speakers, the only one that constantly drops radio stations when playing BBC radio 4 or 3 is your Nest Hub. Let's find the solution for this. What Nest Hub do you have there? Was it working before? If yes, when did this concern started?
Try these: move your Nest Hub near your router, preferably around 5 ft or much closer. Do a sequential reboot starting with your router then followed by your Nest Hub. Restarting your phone might also help.
Keep me posted.
Dan
12-06-2022 01:49 PM
Dan
12-07-2022 12:21 AM
Hi Dan thank you for your help. I'm sorry I haven't replied I am away till Friday so will be able to try it then
I did wonder if the WiFi signal was weKer in that room but no other device has a problem in there and a WiFi signal meter shows its a strong there, or in some cases stronger, than other rooms where Google devices workk fine
12-07-2022 09:24 AM
Hi Richardmn,
We got it. Thanks for the details you provided. A good Wi-Fi signal is another factor that we need to consider as well. Try to move the Nest Hub near the router then observe if this will make any difference. We’ll keep this thread open for 3 days and wait for your update.
Juni
12-10-2022 02:58 AM
Hi. I have tried moving the hub nearer to the router putting it in the same room but this made no difference
12-10-2022 08:48 PM
Hey Richardmn,
Chiming in to ensure everything is covered here. To confirm, are you having the same issue when playing music on your Nest Hub? Also, please provide the firmware and operating system version of your device.
Muddi
12-11-2022 02:18 AM
The system firmware is 7.20220419.2.166
cast firmware is 1.62.312297
playing music from Spotify seems to work fine. I will try a radio station that is not the bbc and let you know how that works.
12-11-2022 02:30 AM
Just tried listening to classic fm on tunein and that doesn’t drop out either si t just seems to be bbc radio
12-11-2022 03:55 AM
And casting from my the sounds app on my phone to the speaker seems to work it just seems to b using the voice control to the bbc sounds app on the nest hub
12-12-2022 06:00 PM - edited 12-12-2022 06:01 PM
Hi Richardmn,
Thanks for trying. It looks like the issue is isolated on BBC. Have you tried reaching out to team to check if they receive similar reports?
Muddi
12-16-2022 08:38 AM
Buzzing in — do you still need our help? Don't hesitate to reach back if you do.
Juni
12-17-2022 09:32 AM
Hello there,
We haven’t heard back from you, so I'll be locking this thread in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Juni
