04-16-2024 02:12 PM
I’m re-setting up my Google Hub and trying to join the Hubs wifi but it’s password protected. Anyone know the password? I don’t remember it being password protected when I initially set it up.
04-16-2024 03:28 PM
Hi @Nicole1026
You just need your home's wifi password. The Hub will broadcast a beacon during set up but that is only for set up.
Follow these steps: Set up your Google Nest or Home speaker or display - iPhone & iPad - Google Nest Help
04-16-2024 05:54 PM
It tells me incorrect password when I type in the home wifi password
04-16-2024 06:52 PM
Are you still trying to join the Nest Hub's temporary Wi-Fi hot spot?
As @JillG pointed out, you install the Nest Hub by going to the Google Home app. See the instructions that were in the link that JillG provided.
