Power adaptor extension
W0LFIE
Hi all, has anyone got any suggestions for compatable extensions for the NEST AUDIO.
I have tried to get the spec for the power adaptor Jack. You need the external jack diameter and the internal pin size.
I want to place mine on a shelf and my nearest wall socket is to far away and I dont want to run mains power extensions around to the shelf. I just want an extension to the jack that I can conceal under the edge of the carpet.
Any suggestions ?
Since this thread hasn't had activity in a while, we're going to close it to keep content fresh. We hope you were able to get the help you need, but if the issue persists feel free to create a new thread, and provide as many details as possible so that others can lend a hand.
