02-19-2022 08:04 AM
Hello, I live in Mexico and since I changed my wifi network provider, I cant connect my Google Home Assistant, I try but tells me to check connection settings. My new provider of Wifi is It is Totalplay , before that I didn't have any problems with Telmex and Izzi. I made a quick search on Google and all I found was a some new mentioning Alexa (amazon assistant) able to connect and use the internet of Totalplay and Izzi in my country. What can I do to solve this situation?
05-05-2022 12:15 PM
Hi esmesaenz,
We hope you were able to get the help you need but if you're still having trouble connecting your Google Home to your network, you might want to check out this link. If the issue persists, feel free to submit another post and provide as many details as possible so that others can lend a hand. Hope this helps!
Alex
