04-20-2025 10:13 PM - edited 05-01-2025 04:58 PM
RadioApp will not load on my Nest Hub Max. Other nest devices in the same household are fine.
Has been working fine, but stopped within the last week or so. Responds to my voice command "Play 3AW' but then the loading process freezes. Other radio services seem fine (iHeartradio) works on the Hub max, but RadioApp does not.
Contacted Google support via email ... the suggested the usual reboot and update solutions ... no change. Opened a chat to Google support, nothing additional to help, but they did suggest to open a Feedback on the issue through the Google home app. When enough people report the same issue, it gets the attention of the next level support people, who should be able to resolve the issue.
** UPDATE **
This is a Google issue ... probably a bug in a recent firmware upgrade that you have no control over.
If you are on firmware level 26.20250116.103.2201 you will probably have the problem.
It is a worldwide issue for Nest Hub devices. Google are aware and some users in the UK have recently reported their problem has been fixed. Hopefully just a matter of time before they roll the fix out to us in Australia ... keep checking.
** UPDATE 2 **
Working here in Melbourne on Friday 2nd May at 9:45am. Was not working at 6:45am.
Seems ok for 3AW , 2GB , 6PR , ABC , GoldFM , Smooth FM , Nova , KIIS ...
... but not for MMM , MMM Classic Rock , FOX FM , 3MP . That is all that I quickly tried.
Interesting is that my firmware level has not changed for my Nest Hub Max. This suggests that there might have been as issue in RadioApp that they are progressively fixing up.
We will probably never know the root cause of the problem, but let's hope they get ALL the stations back ASAP.
05-14-2025 01:27 AM
Radio plays fine on individual speakers here, but with Speaker groups, it acknowledges the command, but nothing plays.
05-14-2025 01:34 AM
and just as I write that it didn't work, after testing again a couple of times, it suddenly started working..
05-14-2025 03:43 AM
Good to know. Check your system firmware to see if it has been updated. Cheers
05-14-2025 12:22 PM
Working in Texas since this morning! Try it now.
05-14-2025 01:29 PM
Can confirm it's working here to 🤗
05-13-2025 01:13 AM
RAYO radio...................Why does this channel not work anymore please I have tried all options it searches for it comes up on the screen and then nothing. Very frustrating I do not want to listen to the BBC channels as like Greatest Hits. the only other option is to ditch the Google unit and go back to the radio!
