RadioApp not loading on Google Nest Hub Max
SteveCairns
RadioApp will not load on my Nest Hub Max. Other nest devices in the same household are fine.
Has been working fine, but stopped within the last week or so. Responds to my voice command "Play 3AW' but then the loading process freezes. Other radio services seem fine (iHeartradio) works on the Hub max, but RadioApp does not.
Contacted Google support via email ... the suggested the usual reboot and update solutions ... no change. Opened a chat to Google support, nothing additional to help, but they did suggest to open a Feedback on the issue through the Google home app. When enough people report the same issue, it gets the attention of the next level support people, who should be able to resolve the issue.
** UPDATE **
This is a Google issue ... probably a bug in a recent firmware upgrade that you have no control over.
If you are on firmware level 26.20250116.103.2201 you will probably have the problem.
It is a worldwide issue for Nest Hub devices. Google are aware and some users in the UK have recently reported their problem has been fixed. Hopefully just a matter of time before they roll the fix out to us in Australia ... keep checking.
** UPDATE 2 **
Working here in Melbourne on Friday 2nd May at 9:45am. Was not working at 6:45am.
Seems ok for 3AW , 2GB , 6PR , ABC , GoldFM , Smooth FM , Nova , KIIS ...
...  but not for MMM , MMM Classic Rock , FOX FM , 3MP .  That is all that I quickly tried.
Interesting is that my firmware level has not changed for my Nest Hub Max. This suggests that there might have been as issue in RadioApp that they are progressively fixing up.
We will probably never know the root cause of the problem, but let's hope they get ALL the stations back ASAP.
478 REPLIES 478
Same here if i don't get Nick and James back soon, I'll go out of my mind listening to Vine  lol
fr45er
Only that I need to use TuneIn. Saying “play LBC UK on TuneIN” seems to work
NWestley
Yay that works!! 👏
Twlldyn
What works please?
Tabbypink
Same issue here, thank you for that, I've finally got my radio back by using TuneIN. Many thanks.
Abulkeek
Same here. I cannot stream any Global Player station on my nest display 2nd gen but no problems streaming them on my other nest speakers.
I factory reset the display and reinstalled it with no avail. Looks like a specific bug with this device and the global player app. Very frustrating and hope someone will either dix the issue soon.
Try playing via Tunein. It works for me 👍🏻
I've just emailed Global app support, but I don't hold out much hope of an answer lol
Yes ! Display won’t play Global but Nest Mini , Nest Audio & Nest Max all will. Who has the issue , Global or Google ? I have to admit as a loyal Google user for audio it’s lost its edge completely and I am seriously considering converting to the other side
** Just found a workaround, if you open the radio station on a working speaker you can then add the non working speaker via the Google Home app then deselect the first speaker, hope that makes sense !**
Also, instruct google to “ Play via Tunein” Works for me 👍🏻
Moggy97
It is also doing the same Rayo
LBQuick
Yes, same problem here. My best home hub loads global player but it then closes. Briefly worked on my other (non display) speakers.
seems to be a google wide issue then, as I thought this was just a case of my account unlinking or something.
Try my work around above , this is working consistently with success
Lindylou
Try playing via Tunein 👍🏻
Jimbo1981
My Google nest is doing the same but say what station you want to listen to followed by tune in.
So say for instance "Hey Google Play Heart Dance Via Tune In" and that'll get around this issue for now.
I have the same problem. Podcasts still working for me, so just a live radio issue I think.
Frankydom
hi yes, this happened to my Nest Hub Max 2 weeks ago, and now, my smaller display 7" has gone the same way. This morning i hope it is a glitch they can fix and not a license issue with global
Im getting exactly the same issue, also the Rayo app for Hits radio isn't working either. All working fine on my home mini's just not on my nest display 😕
Buttercup75
After France Info two months ago, an issue that has still to be resolved by the way, now the same is happening with BBC World Service, be it on :
  • Nest Hub
  • Nest Mini
  • Nest Home Mini
  • Xiaomi Mi Smart Clock
I use the Nest Mini H2C which seems to be more reliable. Whether I ask it in English or in French, it doesn't work. I've tried several French accents and several English accents.
  1. When I ask for BBC World Service, I get KALW
  2. When I ask for BBC Radio World Service, I get BBC Radio 1 Dance
BBC World Service is still available on TuneIn : https://tunein.com/radio/BBC-World-Service-s322318/
When I get to the BBC World Service website, it says "We're replacing BBC Sounds outside the UK and bringing you BBC.com, a seamless way to read, watch, and listen - all in one place."
Could that be the source of the problem ?
I feel like throwing your products out the windows and buying a DAB+ radio.
Chrisko5
We have used out Google Nest Hub to listen to 2GB for a number of years. We live near Port Macquarie and it has always worked perfectly well. A couple of days ago it simply stopped playing 2gb. We can still access other programs like ABC radio however it just will not play 2gb? Please Google can you sort this out?
Tonyteb
I've got the same issue in Melbourne, seems 3aw, 2gb, international radio stations  have all stopped working. But ABC Radio still works as well as Spotify.
gtext
Same issue here. Only one out of the five speakers suddenly stopped playing 3AW. I can get ABC radio on the one that wont play 3AW also. Very strange.
adds360
I can't get any radio station to work on mine, have even tried streaming it from my phone it pop's on the display but never plays any audio
Their saying the bug is fixed maybee April update was cause?
Vicki3
Brisbane is the same
FFrank
I am having the same problem, my speaker works fine but both displays are dead only on 3aw and 2gb. Google can you help us please
Interesting to note, right as we are coming up to an election here the conservative radio stations begin to fail on Google but the Left ABC are fine. It may be suggested that our devices are trying to influence our polling! Fix this Google
Bizarre...I also can stream ABC radio through Radio App but no commercial stations.  All sounds a bit Big Brother
Yes I am having the same problem no radio stations will pick up at all . Have emailed 2GB  radio station to see if there is another frequency to tune in . Was my favourite station to stream all day . Very disappointing. No one seems to know a fix .
chris2468
My ability to play TuneIn radio stations on my Google Nest Hub stopped working on Friday Apr 18th and has not worked since.
Is there a way to troubleshoot this issue?  Currently the only way I have to test is to periodically try again, but there's not output, log files or other troubleshooting methods to determine where the issue is.
Thanks in advance
Ok, by the read of it this is broader than just RadioApp which we use in Australia.
Thanks for posting. We are seemingly all in the same boat, now we wait for Google to help out I think.
Does anyone from Google read these forums?  Or is it just customers?
It would be great to know how to troubleshoot this issue.  I've confirmed the radio station is working fine from the TuneIn website.  This is affecting multiple Google Nest Hubs in my house, so it's not just one of them.  I've power cycled the Hubs, but no change.
Thanks
I also performed a factory reset on one of my Google Nest Hubs and did not change the situation - TuneIn radio stations still are not playing, it plays the regular ads, then attempts to play the radio station, but just shows the TuneIn radio logo a couple of times in a row, like something is failing.  iHeartRadio by comparison, works fine.
and I have the same problem. Streams encoded with the AAC codec don’t work. Only those with MP3
That's interesting, how did you figure out AAC vs. MP3?
My Nest Hub Max will stream Radio, but it first has to be playing on the smaller Nest Hub. I can actually go to the screen on the Max and select the Hub Max to also play the radio. Bit of a work around, and relies on you having both devices.
Interesting angle, one wonders if TuneIn changed their media format on April 18?  I would assume not, as that would break lots of things, such as what I'm seeing here, but wouldn't be the first time a "safe" change ends up breaking things.
Would be nice if there was a way to troubleshoot this, to at least get some error messages or something to know where the problem may be.  Right now it looks like Google, but it's impossible to tell for sure with what we have available to troubleshoot (ie basically nothing) 😞
QueenAeron
A few days ago, both of my Google Home Hubs stopped playing the national ESPN radio station. I was using IHeartRadio (which is my default radio player, I already checked). It says it is connecting, it starts to connect, the IHeartRadio logo pops up and ... nothing! Just the logo on the screen for a minute or so and then it goes back to the clock. I tried unplugging for 30 second, still won't load.
I just tried to load ESPN Radio using TuneIn. It worked except now I have to listen to TurnIn ads. I'm not spending $99/year for something that was free through IHeart.
What update from Hades did Google upload that broke my ability to listen to sports radio.
I'm having the same issue (not able to play anything on iHeart Radio or Audacy).  This is with the Google Home Hub.  However, both work fine on my Hub Max.  Also unable to Chromecast iHeart or Audacy to either of my Home Hubs.  Both worked fine previously.
Wendywooz
I have the same problem. Have reported to google several times and to RadioApp.. i have heard nothing back. I have also contacted several radio stations for help, but its not them as other friends are still able to use RadioApp on their home googles.. i have also factory reset it .. have deleted an reinstalled the home app also.. nothing has helped.. after 2 years with no problems and now silence, its nice to know i am not the only one
Sammy80
Thank God it's not just me. It's been frustrating me for the past fortnight.
Not very helpful when I use Heart UK to wake me up as part of my morning automation 🤣
