Using nest hub max as a matter hub
GuyLevin
Hello
I'm trying to set up a matter device (esp32) with a nest max hub (preview program v.8.2)
It is paired using the google home app and shown correctly in the devices list. It also gets connected to the wifi after pairing.
But when I try to change its status from the google home app, it just says "something went wrong"
I can see many announcements that the nest max hub (and other 1st gen devices I have as well) will be used as a matter hub, but I can't find reference that mentions if it supports it already, or when it will be supported.
2 REPLIES 2
SOPR
I have the same exact problem, did you find a solution?
Muddi
We're glad to hear you're interested in using Matter devices on your Google Nest Hub Max ! No news about that right now, but stay tuned for more news and updates.
Muddi
