03-02-2023 12:23 AM
When I'm trying to talk to someone that I can see (via hub max camera linked to my android phone), I can see them, they can hear me, I can't hear them. Why can't I hear them? The mic on the hub works fine because it responds to commands when I'm with it. Thanks
03-06-2023 04:18 PM
Hi en7edh,
This is not the experience we wanted you to have, let me help you. A few things: when did your issue begin? Were there any recent changes made? What country are you in? To confirm, is this happening when making Duo calls?
It would help a lot if you could do a sequential reboot first:
Check this guide for options about our calling features.
Keep us posted.
Dan
03-07-2023 12:01 AM
Thanks for the follow up. I've tried multiple reboots and IP address configurations in the past. Its always been a problem since I installed the hub about 6 months ago.
Let me describe the situation more clearly. If I'm away from the hub (different town or just different room) I can clearly see the Nest video feed. However, I can't have 2 way audio.
I messed around with it this morning and it turns out I can hear what's going on if the mic is switched off on the mobile device. So essentially the nest hub is giving me 1 way comm's at any time, which is a bit rubbish. My Ring doorbell manages simultaneous 2-way comm's.
To answer your other questions, I'm in the UK and I don't make duo calls. I'm just talking about being able to communicate with whomever I can see in the hub's video feed, via my mobile device.
Thanks
03-08-2023 04:50 PM
Hey en7edh,
Chiming in to ensure everything is covered here. Let's go ahead and reset your device. Please note that it will remove all the settings on your Nest Hub Max and it will require you to set up the device again. Also, make sure to save important footage from the device's video history and remove your Nest Hub Max from the Google Home app first before resetting it.
Let us know how it goes.
Muddi
03-09-2023 01:50 AM
Hi Muddi,
before we go down the drastic measures route, are you confirming that simultaneous 2-way audio is supposed to be possible between an android smart device and the hub?
thanks
Elliot
03-11-2023 03:02 PM
Hi en7edh,
Chiming in ― the 2-way audio should work between your Nest Hub Max and the Google Home app on your phone when you select the “view Nest cam” option. I’ve tested the feature again on our test device and it worked like a charm.
If you could try to replicate the issue, please do! If it persists, then follow the steps above for the factory reset to revert your Nest Hub Max to its original settings. Remove the device first from your Google Home app before doing the factory reset.
Dan
03-12-2023 01:22 AM
Great. Thanks. I have just tried it in the home app. It worked! I was previously using the Nest app, which I will likely just delete.
Many thanks
03-13-2023 05:14 PM
Hey there en7edh,
Perfect! Google Home app is the key.
As we got our resolution here, I'm going to mark this thread as resolved. I'll be locking this thread if we won't hear back from you in 24 hrs. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Dan
