03-04-2022 11:59 AM
Does anyone know what percentage i need to have the volume on for 50 decibels on the google home mini?
03-04-2022 12:45 PM
Hi Princess831,
The volume of a device can differ depending on the environment it is being used in so it's not possible to answer your question.
I suggest watching some YouTube reviews to get a better idea....
Cathal
03-04-2022 01:44 PM
I agree with Cathal. The easiest way to do what you want is to install a Sound Pressure Level (SPL) monitoring app such as Sound Meter on your phone and adjust the Mini's volume until the scale reads 50dB which, by the way, is a very low level --- basically background noise. Here is a screenshot from that app:
Good luck!
-Sam
04-28-2022 02:23 PM
If you have additional questions, feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
Princess
