Where can I get a Nest Audio power cable replacement in UK
CCT1979
Where can I get a replacement cable for my Nest Audio speaker? The only similar question on here directs to a spec sheet for the speaker, this only gives details of wattage and voltage requirements and does not detail the type of connection etc which appears to be non standard as there's no central pin for the plug that goes into the speaker.
frances
Hello CCT1979,
Thanks for reaching out. I would be more than happy to help answer your question. First, I have some quick questions regarding this situation.
  • First, we do not sell power cables on the Google store.
  • Is your power cable no longer working? Could you please provide me some details of what is happening?
  • Is your device under warranty? When did you purchase your device?
Thank you for your patience, I look forward to your response!
frances
Hi All,
It's been a few days since we have heard from you. Just checking to see if you were able to see my response above. I look forward to your response, we're here to help!
frances
Hi All,
We haven't heard any updates from you. I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
