06-19-2025 02:59 AM - edited 07-10-2025 02:09 PM
I’m experiencing a display issue on my Chromecast with Google TV (4K) device since updating to Android 14.
Whenever I play Dolby Vision content in Exo/Media3(ex stremio, jellyfin) then exit back to the home screen, the system remains stuck in Dolby Vision mode, instead of switching back to SDR as expected. This causes the entire UI to appear washed out, overly dark, and improperly calibrated.
I have “Match content dynamic range” enabled, and this behavior worked correctly on Android 12, where the system would return to SDR after playback. This issue only began after the Android 14 update — so it’s clearly a regression introduced in the latest system version.
Please note:
This is not related to my internet connection, router, or display hardware — it’s a firmware-level video output bug reproducible across multiple displays and setups.
I’d appreciate it if we could avoid generic troubleshooting questions that aren’t relevant to this issue.
Manually switching the resolution to SDR resolves it temporarily, but obviously that shouldn’t be necessary.
Please let me know if this is a known issue or if a fix is planned.
06-27-2025 04:48 PM
Hi tsoltan,
Thanks for posting here in the community. I understand you are experiencing an issue on your Chromecast with Google TV (4K) since updating to Android 14. Specifically, after playing Dolby Vision content through Netflix and then returning to the home screen, the device gets stuck in Dolby Vision mode. I'm here to help!
To better understand the situation, I'd like to ask a few questions:
In the meantime, please review the following:
We value your feedback, as it helps us constantly improve our products to meet your needs. For instructions on how to submit feedback reports, please use the keyword 'Dolby Vision Stuck After Exiting Netflix – Regression on Android 14', please refer to this article: Send feedback from the Google Home app.
Keep me posted.
Melany
06-28-2025 01:03 AM - edited 07-10-2025 02:09 PM
I'm currently on firmware version UTTC.241218.008.H1.13427172 (Chromecast with Google TV 4K).
Ever since the Android 14 update (starting from UTTC.241218.004), I've been experiencing an issue where Dolby Vision remains active after playback ends.
The issue is reproducible with multiple apps (e.g., Jellyfin, Netflix) and results in the system staying locked in Dolby Vision output even after exiting the video.
The TV continues to indicate Dolby Vision input, and the system doesn't revert back to SDR as expected.
This problem did not exist on Android 12 — HDMI output mode was reset properly after DV content.
Importantly:
- Match frame rate is enabled
- Match content dynamic range is enabled
- No issues with plan HDR
Please escalate this as a regression in HDMI/EDID handling after DV playback in Android TV 14.
07-11-2025 03:10 AM
@gmelanymelissa Any updates? I filled feedback form several times - but didn't get any response
07-14-2025 07:34 AM
@GoogleNestTeam Do you have any updates on this, I've sent logs several times?
07-22-2025 12:26 PM
@gmelanymelissa Any updates I've sent feedback from the google home app?
07-29-2025 09:21 AM
@gmelanymelissa any updates?
07-08-2025 01:46 PM
Same issue with jellyfin
07-10-2025 04:46 AM - edited 07-10-2025 04:48 AM
Attached resolution form media3 team
https://github.com/androidx/media/issues/2595
Based on your description, this would not be an ExoPlayer issue as ExoPlayer does not set the Display into Dolby/SDR mode. That might be an issue with the Chromecast or your TV. I'd definitely suggest logging feedback with those devices for this issue.
I've also tested on the other TV the same issue - So the issue with Chromecast with Google TV 4K - What else I need to provide to make you fix the issuse?
07-16-2025 12:33 PM
I'm also having the issue with other devices such as the Google TV Streamer and the Xiaomi TV Box S 3rd generation, so it could be a general bug on the Android 14 master build.
07-17-2025 11:09 AM
Was able to replicate the issue on Xiaomi TV Box S 3rd - so probably it is the issue with ATV14 across multiple devices
07-19-2025 03:26 AM
Also having such issue on Chromecast with Google TV (4K) connected to Sony TV.
DV mode stuck after watching DV content on media3/exo-based apps (was using Jellyfin). In order to reset it, I have to play sdr video, but in case I don't do it everything gets stuck in DV, menus other apps .
Please fix it.
07-25-2025 12:52 PM
Created also issue on
https://issuetracker.google.com/issues/434213619
so if anyone experience the same issue - please report also there
07-30-2025 11:31 PM
Mine does the exact same thing, really annoying. Thinking of just getting an apple TV instead.
a month ago
@gmelanymelissa - any updates on the issue?
Why this topic is being ignored? It's been 2 months - Do I need to create a new topic?
2 weeks ago
I have the same issue after updating to Android 14. After playing Dolby Vision content via Plex the system stays stuck in Dolby Vision mode.
