01-21-2023 02:05 AM
Hi!
A few weeks back, my GCCwGTV stopped controlling my dumb LG TV after working perfectly fine for over a year. Even after several re-pairs and hard resets.
A few days later it stopped working completely, so I changed the batteries and it went back to working, except for the TV controllers.
It drained the new batteries within a week or so. I figures it was from all the pairings and factory resets I have made so I got new (better quality) batteries, which lasted one more week.
After browsing some forums I pointed my phone camera at it and realized that the IR signal is ALWAYS ON. No flickering when I press the buttons, and it doesn't stop until I remove the batteries. There are no buttons stuck and there was no damage to the remote. What can I do?
I don't want to lose the TV controller functions and definitely don't want to change batteries every week.
Thank you.
01-24-2023 03:18 PM
Hi p88slv,
Thanks for reaching out and I'm sorry to hear that you're having an issue with your device. The IR signal is always on as it is used for the remote to communicate with the TV or to work for many devices. If the Voice Remote isn't working, please try the additional steps below:
Let me know how it goes.
Jennifer
01-30-2023 08:54 AM
Hello there,
It's me again. I want to make sure you're all good — how did the steps go?
Jennifer
01-31-2023 08:56 AM
Hey p88slv,
Just checking in to make sure that you've seen my response. Please let me know if you still need help or if you have other questions or concerns as I will be locking this in 24 hours. Feel free to start a new thread and we'll be happy to help.
Jennifer
01-31-2023 02:30 PM
Hi Jennifer,
Thank you for your follow-up, it is greatly appreciated!
I did it all, including the factory reset to the chromecast itself and still nothing. The remote continues not to control my LG TV, despite being automatically configured to do so during the initial chromecast set up, after the factory reset.
So now I am at the same position I was initially, after an hour of reconfiguring everything, reseting most of my apps passwords and reinstalling all the apps.
I'll keep the new batteries on, to see if they will still drain after a week.
Is there any other solution?
Alternatively, can I buy a new remote? I live in Portugal, so it's not available in the Google Store here.
And do you think a new remote will solve my problem?
Thank you
02-05-2023 02:36 PM
Hello p88slv,
I appreciate you trying the suggested steps. Could you tell us if the battery is still draining?
It's not a guaranteed fix but, you can try to purchase a new Voice Remote at the same store where you initially purchased your device. Once you have the new remote, you may test and observe the behavior of the device. You can also check this support website article to set up the buttons on your Voice Remote.
Jennifer
02-08-2023 02:48 PM
How's it going? Do you still need help?
Jennifer
02-09-2023 03:03 PM
Hey p88slv,
I haven't heard from you in a while so I’ll be locking this thread after 24 hours. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the Community.
Jennifer
