11-25-2024 07:59 AM
I changed one of the logged in accounts on my Chromecast/GoogleTV to be a supervised account and was forced to factory reset the device.
Following a factory reset, I attempted to set up the remote volume buttons with my Soundbar (IR Mode).
The soundbar is a Philips HTL2160. On selecting Philips devices, the pairing process cycles through 5 codes. None of them work. It then flashes up a message of "it looks like I can't control this device".
The remote was previously paired and controlling the volume on this device before I performed a factory reset.
The Chromecast and remote both have the latest firmware.
Is there any way to retrieve and use the pairing code that the remote was previously using? Or any way for the remote to 'learn' the codes required?
11-27-2024 12:53 AM - edited 11-27-2024 12:54 AM
If the volume buttons on your Google TV remote no longer control your soundbar after a factory reset, it’s likely due to the need to reconfigure the remote to control external devices. Follow these steps to resolve the issue:
Open Remote Setup:
Select Volume Control Device:
Follow the On-Screen Setup:
Ensure HDMI-CEC is Enabled:
Check Your Soundbar's CEC Setting:
If the above steps don’t resolve the issue, factory reset the Google TV device again and repeat the remote setup process carefully. Spotify++
Let me know if these steps resolve your issue or if you need additional help!
11-27-2024 03:04 AM
Thanks for your pointless response. Please read posts before blindly replying to them with generic cop&paste responses.
As previously stated: I am trying to configure an Infra-red controlled soundbar that was previously working before the Google TV device forced me to perform a factory reset. It is not HDMI-CEC.
I have been through the reconfiguration process several times and the 5 available codes for my brand have been used up without success.
I have even tried to configure it under a different brand as suggested on other issues - but have still had no success.
The Chromecast and remote both have the latest firmware. The remote was controlling the soundbar volume minutes before I performed the factory reset.
Is there any way to retrieve and use the pairing code that the remote was previously using? Or any way for the remote to 'learn' the codes required? Or a system to file this as a bug report with Google? A further factory reset is unlikely to solve my issue.
11-28-2024 06:18 PM
Hello iainmc,
Thank you for taking an interest in our community. I understand that your Chromecast with Google TV no longer controls the soundbar after performing a factory reset. Do not be concerned; I’m happy to assist.
Here I have some recommendations:
Set up volume, input, and power
Volume
Please let me know if these suggestions were helpful.
Daniel
11-29-2024 03:34 AM
What is the point in posting issues in this forum if nobody actually reads them and just posts generic setup information?
As previously stated: I have been through the reconfiguration process several times and the 5 available IR codes for my brand have been used up without success.
I'm guessing the answer is no.
11-29-2024 04:06 PM
Hey iainmc,
Thank you so much for keeping me updated. I understand how frustrating it must be that this situation hasn't been resolved.
The team would like to learn more about this behavior. When you get a chance, please fill out this form and let us know when you’re finished. We’ll have someone reach out to you via email from there.
Daniel
12-26-2024 06:29 PM
Fabrika ayarlarına sıfırladıktan sonra Chromecast uzaktan kumandanız Philips HTL2160 soundbar'la eşleşmeyebilir. Diğer Philips kodlarını test etmeyi, uzaktan kumandayı sıfırlamayı veya Google Home uygulamasını kullanmayı deneyin. Oyun oynamak için Chromecast Stadia, Android oyunları ve Bluetooth denetleyicilerini destekler. Daha fazla ipucu için https://minescraftapks.com.tr/ adresini ziyaret edin.
