Stuck on load with multicolor flashing screen
Clownbutts
Hello.
I turned on my Chromecast 4k today, and just got this flashing screen. It doesn't load past this.
Kimy
Hi Clownbutts,
Thanks for posting here in the Google Nest Community. A few questions: what Chromecast device are you using? How long have you been using it? When did it start? Also, what steps have you taken so far? Give the steps below a try and let me know how it goes:
  • Reboot your Chromecast device, TV, and Wi-Fi router.
  • Switch to a different HDMI port.
  • Switch to a different power source or a different power cord.
  • If it fails, try a factory reset, then re-setup.
Kimy
Green_jose1
I had this once you just need to move it to a new HDMI port
Alex_S
Thanks for sharing a resolution here in the Community, @Green_jose1
@Clownbutts, have you had the chance to try the suggestion above? If yes, how is it?
Sincerely,
Alex
Clownbutts
I had tried resetting, changing the HDMI port, all of that, but it eventually just fixed itself when it decided that it was ready to.
Alex_S
Hello Clownbutts,
I’m glad to hear that the issue has been resolved. It looks like I can consider this one complete, so I will lock the thread in 24 hours unless I can help out with anything else.
Alex
