Up button on Remote control not working correctly
Adelc
The up button on my remote control is not working correctly, sometimes I need to press 2 or 3 times to get a reaction or pressing very hard.
I deed a factory reset, unpaired, remote firmware update nothing helps
To be noted only the up button (on the wheel)
Byteguy
Unfortunately, that sounds like a hardware problem.  It's not something you can fix with a reset or repair yourself.
If your device is still under warranty, you can ask for a replacement.
https://support.google.com/store/answer/6160400
If it is not, you can order a replacement from https://store.google.com or, if you have a compatible device, use the Virtual Remote in your phone:
https://support.google.com/chromecast/answer/11221499
Byteguy
