how to open battery compartment
LucieA
Cannot open battery compartment
JillG
Hi @LucieA
You really need to press hard to slide the battery compartment open. On the back press and slide the cover.
Jill
JillG
Hi @LucieA
Jill
LucieA
I had to find something thin and strong to pry it open.  Pressing was not sufficient.  Not a good design.
JenniferV
I appreciate your help, JillG.
LucieA, you might feel it's hard to remove the battery cover. This design is intentional, but if you can't remove the cover when you slide it forcefully, you may try the steps below:
  1. Stick one end of a cellophane tape to the bottom of the back of the remote. Use the other end of the cellophane tape as a pull tab.
  2. Pull the end of the cellophane tape as you press the circular dented surface firmly (refer to the following photo).
Also, we'll take this as feedback as we're always looking for ways to improve our products. I'd suggest you send feedback about this via Google TV. Here's how.
Let us know if you still have questions and concerns otherwise, we'll be locking this thread after 24 hours.
Jennifer
