Problem with MI SMART CLOCK and V-TAC Lights
Alex82nc
Dear all,
I have problem with my Mi Smart Clock and V-TAC light.
When i try to drive the light V-TAC from the Mi Smart Clock device, it not working fine. But, otherwise, if i try to use a normal cellphone device android with google assistant it working fine.
Could you help me in this matter?
Thanks and regards
Alex82nc
Seem that it could be solved setting the correct lenguage on Google Home. "Settings" --> Google Assistant --> Set all the settings of the assistant --> Lenguage.
After you set the correct lenguage the assistant seem to be ready to accept the vocal command.
2 REPLIES 2
Alex82nc
Alex_S
Hi Alex82nc,
Thanks for sharing the resolution you found here in the community. Please note that we have limited support for third-party speakers with a built-in Google Assistant, like your Mi smart clock. It is best to contact Xiaomi support for better assistance. The integration of Google Assistant into third-party devices like your Mi smart clock may differ from that of Google Home or Nest speakers.
Kind regards,
Alex
