Activate google nest door ring camera
Cinnamonslim
We have recently purchased a new home and the home has a google nest camera installed. How can we activate it if we’re not able to access the QR code or serial number as it is attached to the home and difficult to remove.
David_K
Hi @Cinnamonslim
Unfortunately you’ll need the QR code or setup key which are physically printed on the device. I'd recommend writing down the setup key, so you have it should you need it again in the future.
Set up and connect Nest camera - Google Nest Help
If the previous homeowner hasn't reset it, you'll first need to factory reset it to be able to set it up.
Restart or factory reset Nest camera or doorbell - Google Nest Help
