03-23-2022 06:59 PM
I bought the antitheft device for the Google camera but it only seems to work with the battery version will the antitheft device work with the floodlight too?
03-27-2022 07:49 AM
That's correct, it's designed to work with the outdoor or indoor battery versions. Personally, I don't find it necessary for the floodlight version as that is already tethered to the base. In any case, I am sure it would fit the camera, the problem might be the chain/wire part as it's only 8 inches long. If the body of the floodlight is longer then 8 inches it may not reach behind it to be secured by one of housing screws you will use to fasten it to your house.
05-05-2022 09:50 AM
Thank you for all of your help, @David_K!
05-10-2022 10:12 AM
Just checking in to see if you still need assistance with this issue. We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
05-12-2022 12:57 PM
Hey Folks.
