08-26-2021 11:29 AM
Original poster: Duy Nguyen 1089
08-26-2021 11:29 AM
09-02-2021 02:27 PM
Hi
I can’t connect the battery doorbell to Alexa. Can the google home app ( rather than the nest app ) be connected to Alexa
09-02-2021 03:26 PM
Hi there, Carolynlock.
To answer your question; yes you can connect Alexa to the Google Home App as the Nest Hello Battery Doorbell is not available on the Nest App. All of our cameras work with voice assistant technology. Try setting it up again within the Google Home App. You can check out this article here for more information on getting Alexa set up with your Cameras.
Please let me know if you need further assistance. I look forward to your response.
09-02-2021 11:13 PM
Hi I have now connected battery doorbell to google how thanks. Although I can’t connect it to Alexa. Alexa can only see my nest thermostats. It appear the Alexa skill is only linked to the nest app and not google home. I can’t find anyway to connect my nest battery doorbell to Alexa. I’ve called Amazon and they can’t help. Do you know how I connect the battery doorbell to Alexa.
I’ve read the google support pages and no answers there
10-06-2021 07:50 AM
I have this same issue - I have connected my Alexa to the Nest Thermostat and Nest Cameras (indoor and outdoor) but CAN NOT connect my Nest Battery Doorbell to my Alexa. It appears to be because the Alexa Skill is only linked to the Nest App (the Battery Doorbell is NOT in the Nest App) and not to Google Home. Any progress on this?
10-06-2021 09:29 AM
Hi you are right this is the issue. I can’t find a solution. The google battery doorbell can’t be connected to Alexa
12-01-2021 10:44 AM
I’m having this same issue. I recently bought the echo show thinking it was compatible with my doorbell and cameras, but Apparently any google battery devices are not compatible with Alexa which is really inconvenient.
