08-23-2022 05:16 PM
Hello
My nest doorbell is connected and the light is blue. The final step of connecting my doorbell to my Wi-Fi is the problem. It’s not connecting to my Wi-Fi that’s connected to my phone.
I’ve checked the password multiple times to make sure it’s correct, and still doesn’t connect. Any suggestions? @
Thank You
08-28-2022 08:52 PM
Hi Baldhead49,
Thanks for reaching out! I'm sorry to hear that and for the delayed response. Thanks for trying, let's sort this out — a few questions: was there an error message/code you received during setup? How far is your Nest Doorbell (battery) from the router? Also, do you have an Android or iPhone?
Try the troubleshooting steps here:
Let me know how it goes.
08-31-2022 10:44 PM
Hi Baldhead49,
It's me again. I want to make sure you're all good — how did the steps go?
09-05-2022 05:07 PM
Hey Baldhead49,
I appreciate the help, JT.
Archie
09-06-2022 06:15 AM
Hello thanks for reaching out I am still without my doorbell. Google sent me out a new doorbell but I still can't seem to connect to my wifi I have done multiple restart to the router I am stump at this point!
09-06-2022 08:58 AM
I am so sorry to hear that you still haven't been able to install your Nest Hello! Have you tried to Factory Reset the device? This is different from a restart. I wanted to remind you of some Important things to know before you factory reset. After you factory reset your camera or doorbell:
Important: Because a factory reset permanently erases the items listed above, we don’t recommend doing it as a troubleshooting step until you’ve tried restarting your camera and other troubleshooting options.
09-06-2022 09:43 AM
Thanks for your Brad
Google sent me out entire new doorbell and it still not connecting to my wifi. I have restart the router tried to setup on different devices still not connecting to wifi at this point I feel its not the doorbell it must be something with the internet. But I have about 10 other google devices connected to my home network.
09-06-2022 10:25 AM
I am very sorry to hear that your replacement device isn't connecting to your internet! Do you have a dual-band router? If so, try switching the Wi-Fi channel and see if that does the trick. That can help some users, from what I've seen.
09-07-2022 11:38 AM
