01-17-2025 10:05 AM
I am not able to have the nest doorbell connect to the nest hub. It sends notification to my phone but not the hub. Tried resetting...and no help...
01-17-2025 10:28 AM
Are your Nest Hub and battery doorbell in the same Google Nest "home/structure"?
Do you have "Visitor announcements" (https://support.google.com/googlenest/answer/7672451) enabled in the Google Home app for your battery doorbell? ("Visitor announcement" for when the doorbell button is pressed are the only notifications that Google Nest doorbells can send to Nest Hubs.)
01-17-2025 11:24 AM
Visitor announcements are enabled. When the doorbell is pressed it rings my Google speaker in the garage but nothing shows up on the nest hub
01-17-2025 11:25 AM
I was thinking about doing a complete factory reset on all apps and the hub see if that will help
01-17-2025 11:46 AM
On your Nest Hub, is "Do not disturb" turned on? If so, that blocks "Visitor announcements".
01-17-2025 12:28 PM
It is not turned on
01-17-2025 12:47 PM
I can't think of any other likely causes.
Are you also unable to view your doorbell's camera on the Nest Hub?
I think I've seen a few other similar posts regarding "Visitor announcements" with the battery doorbell.
Maybe Support would have some insights:
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
01-17-2025 12:51 PM
I appreciate it. I might just factory reset all devices. Including the hub
