12-28-2023 05:02 AM
Try to charge battery but it shows it is not connecting anf off network. What is the solution?
12-28-2023 08:20 AM
Is this the first time you've tried to charge the battery on your battery camera? Is the charging cord plugged into the bottom of the camera with the cord feeding towards the FRONT of the camera? When you plug in the charging cord, does the status light pulse white while charging? And when fully charged, does it change to a solid white light?
If you can't resolve it, you can use the link and instructions in the post below to contact Support:
12-31-2023 09:21 PM
Hello Gemg_gem,
Just wanted to check in and see if you tried out the steps that MplsCustomer shared with you. Did everything work out okay? If you need any more help, just let me know.
I appreciate the help, @MplsCustomer.
Edmond
