11-21-2021 04:14 PM
I am hopping to add a wireless doorbell to my security system. The ADT doorbell does not work unless the home is hard wired for a doorbell. I am looking at wireless applications to connect to my ADT system.
I was told that the nest doorbell is comparable and before I purchased one I am looking for some confirmation if wireless doorbell can or cannot connect to my ADT command and control system.
01-04-2022 03:15 PM
Sorry to keep you waiting on a response! You would not be able to use the Nest Hello doorbell with your ADT system as it is a smart doorbell, is not considered a security system. You can find out more information on the Nest Hello Doorbell both wired and battery powered, here. Please let me know if you need further assistance.
02-04-2022 10:48 AM
02-07-2022 11:53 AM
Hey Folks.
