Camera Won't Stay On
gnovak
My outdoor cam battery ran out. I tried to charge the camera and I couldn't get a light/signal that it was charging (plug was in correctly). Things I tried:
* Cleaning connections
* Tried multiple outlets
* Unplug, Plug in, unplug, plug in....
* Restart and Factory Restart
I finally got the indicator light to come on and my app said it located a new device. I went through the entire setup process, which included scanning the barcode, renaming, setup, etc. I did have video through the new setup and once everything was complete, I verified it was fully charged.  When I removed the charger, the camera light turned off and I lost the signal to the app.
Now I can't get a signal to the app nor can I get a light to come on the camera.
Is the camera dead at this point?
@gnovak
We've had a battery camera since Sept. 2021, plugged in with the optional power cable, and it's always "Live" and online.
I don't know how the battery cameras perform over time when they're running on battery power and being charged regularly. You could try contacting Support to determine whether your camera needs a warranty replacement:
@gnovak
