04-09-2022 08:32 AM
How do I change batteries in my outdoor cameras
04-09-2022 12:20 PM
We have a Google Nest Camera (Battery), introduced in 2021. The battery cannot be changed. That's one of the reasons we have ours plugged in all the time with the optional power cable.
04-12-2022 04:20 AM
Thank you. However our cameras are located outside so no access to a plug
04-12-2022 09:38 AM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I definitely understand how frustrating your situation must be, and I wanted to make sure that your concern was acknowledged. You will need to access the camera in order to charge it. No way around that. If you do not want to worry about charging it, then I would suggest that you install it as a wired device.
04-20-2022 09:16 AM
Have a great day,
Garrett DS
