09-28-2021 01:41 PM
My driveway gate is too far for a stable WiFi connection. Is there anyway to connect to a camera using an ethernet cable? I have a conduit out to the gate and also power.
09-28-2021 02:12 PM
For the new (battery) cams this 3rd party company makes a cable that will save the problem but it isn't out yet. Keep in mind the NEW nest cams are a mess when it comes to features since you can't use the older NEST app with you. You are stuck with the GOOGLE HOME app and there is also no way to view these new cams on your computer. I ended up returning the new cams because of the limitations compared to the older cams.
10-08-2021 01:08 PM
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I just wanted to make sure that your issue is addressed. I can definitely understand how frustrating your situation must be. I would love to help you find a solution to this issue.
Do you still need help with this issue?
What troubleshooting steps have you done thus far?
11-12-2021 01:21 PM
Have a great day,
Garrett DS
