Camera does not pick up animals much
Peep-eyE
I have the sensitivity turned to high, I have animal and motion options enabled, I also have zones set like tech support told me to use when I called them.
I set a 2nd camera up on the ground and it showed animals coming through numerous times all night long. Possums and raccoons. But my main camera, a wireless google nest camera, that overlooks this area, 8 to 10 feet away, only picked up the possum 1 time early in the night then never picked it up again, and never recorded the racoon.
Part of the reason I bought these google nest cameras was to see stuff day and night around my house, shouldent it be recording these events?
My wireless google nest cameras (bought this year) and my Samsung s23 galaxy are up to date.
When this post asked me to pick issue catahory I picked "getting started" although I'm not getting started, i started a while ago...I did not know what category to pick for this.
2 REPLIES 2
mdr2
Hello,  I'm an end user as well and I have the same intermittent issue.  I have 2 cams in my back yard and sometimes they notify me of the stray cat and sometimes they don't.  And sometimes only 1 camera alerts me.  I have one close to the ground it does better than the one the is mounted higher up.     But I have to say I also have 2 other brand of cameras and they both have the same issue.  I don't think any of these companies have really nailed-it when it comes the algorithms that spot movement.
zoeuvre
Thanks for chiming in, @mdr2
@Peep-eyE, uh-oh! I understand that you're experiencing issues with your Nest Camera not consistently capturing animals in its field of view, despite having the sensitivity set to high and the appropriate settings enabled. Here are a few suggestions to help improve the camera's performance:
  1. Ensure that your camera is positioned correctly to capture the desired area. Consider adjusting the camera's angle, height, and field of view to maximize its coverage. Make sure there are no obstructions, such as branches or objects, blocking the camera's view.
  2. Check the lighting conditions in the area where the camera is installed. Insufficient lighting, especially during nighttime, can affect the camera's ability to detect and capture animals. Consider adding additional lighting, such as outdoor lights or infrared illuminators, to improve visibility in low-light conditions.
  3. Verify that your camera has a strong and stable Wi-Fi connection. Poor Wi-Fi signal strength can affect the camera's performance and ability to transmit video recordings. If the camera is located far from your Wi-Fi router, consider using Wi-Fi extenders or mesh Wi-Fi systems to improve signal coverage.
Let us know how it goes.
