02-29-2024 06:46 AM
Camera not recording video even with nest aware
02-29-2024 08:27 AM
You might want to contact Support and go through some troubleshooting (see below).
But here are a few things to check:
1) In the Google Nest app, under Settings for your camera, is "Video recording" turned on?
2) Are you using these instructions for accessing video history in the Google Nest app? https://support.google.com/googlenest/answer/9208447
3) Is your camera in the same Google Nest "home/structure" as your subscription?
4) Does your subscription show as active here? (https://store.google.com/subscriptions)
To contact Support:
03-04-2024 08:53 AM
@edfederle, thanks for posting in the Community. I wanted to check in and see if you still needed any help. Have you managed to contact our support team as suggested by MplsCustomer’s response above? If yes, how was it?
Also, you can use this interactive troubleshooter to help you troubleshoot event video history.
All the best,
Lance
