Camera wired
Mlillo
It is plugged I have Wi-Fi and it is showing a green light. I have unplugged for 10seconds and that doesn’t work.
2 REPLIES 2
@Mlillo
What exactly is happening? Did your camera just quit working or are you trying to install it? What error messages or other conditions have you encountered? Do you have a 1st gen (Google Nest app) or 2nd gen (Google Home app) indoor camera?
Thanks for reaching out. I just want to check if you managed to see the response above. Could you please tell us more about your concern? Also, share with us the needed information, as it will help us to move forward.
I appreciate your input, @MplsCustomer.
