05-12-2023 05:14 PM
2 cameras and 1 door bell camera all went off line. My bill is paid. How do I fix?
05-12-2023 05:49 PM
Did your wifi go offline ? Would suggest you try rebooting your router first to see if that fixes issues.
05-12-2023 06:42 PM
My Nest IQ outdoor cam went offline multiple times, then stayed off. Support couldn’t help. I’ve “fixed” this issue twice now by removing the device and adding it back in. This could get old.
05-12-2023 06:58 PM
You fixed it by reconnecting the camera then they went offline again, question is can you test to see if the signal is just too low where the cameras are located? Maybe set one up near the router for a day to see if it stays online..if it doesn't then at least you can knock signal issues off the list right?
05-12-2023 07:44 PM
The camera and the router are exactly where they’ve been for 5 years, and my phone shows the wifi signal is strong there. The last time I “fixed” it by removing/adding the camera it worked fine for a full week. I’ll have to see how long it works this time. (But Ashepherdson, thinking about your suggestion… I might try this if it fails again. I wonder if the power adapter and usb cable are the same as most usb-c devices. Pulling out the camera’s cable for such a test would be a BIG hassle.)
05-12-2023 07:47 PM
For the cable it should be the same, the tech specs are below. Fingers crossed it stays active but you never know. As for the wifi signal, it's a long shot I know, but things do happen sometimes so it's not a bad test to run if you can.
Power input
100–240 V AC, 50/60 Hz, 0.65 A
Power output
15 V DC, 1.8 7A
Cable
Length: 7.5 m
05-12-2023 08:21 PM
I’ll try it if the problem recurs. Thanks!
05-24-2023 07:04 PM
Thanks for the help here, Ashepherdson.
Cher1 and CarlInATX, thanks for reaching out. I just wanted to follow up if you were able to try the steps provided. Please let us know, as we would be happy to answer any questions you may have
Juni
05-29-2023 03:18 PM
I want to check if you have additional questions and concerns about your device. Let us know by updating this thread, and we're glad to assist you further.
Juni
05-30-2023 06:21 PM
I haven’t learned anything new, but I’ve gotten much faster at removing, then adding, my camera. It continues to work flawlessly for 7-8 days, then fails hard. I still suspect it’s an account problem. Btw, my current account gives me 24/7 recording for $50/year, whereas the new Google version they constantly ask me to upgrade to is $120/year. Maybe this 8-day failure problem is Google trying to nudge me to upgrade. 😉
05-30-2023 06:35 PM
CarlInATX, Im glad that worked for you.
Cher1, I just wanted to follow up to see if you still need our help. Please let us know, as we would be happy to answer any questions you may have.
Juni
05-30-2023 05:39 PM
Hello there,
Juni
05-12-2023 06:47 PM
Rebooted modem and still doesn’t work.
05-12-2023 06:56 PM
Sorry just to be clear, you rebooted your modem ...or your router?
