08-02-2022 12:47 PM
I have 2 wired doorbells and they are never able to stay connected at the same time. Recently the front doorbell went offline and won't come back on. I've tried everything listed, restarted internet, restarted doorbell, factory reset, and removed it from the account. In trying to set it up again NOTHING I try is working. I'm getting very frustrated that it won't connect again. Is there something wrong with the actual doorbell and not the connection problem?
08-08-2022 05:44 PM
Hey NCoviello,
I’m sorry you’re having trouble with this. No worries, we'll check this out. Are you getting any error messages? How far is your doorbell from your Wi-Fi router? Also, what's the status light of your doorbell?
Archie
08-09-2022 03:17 PM
Hi Archie,
The button is blinking blue and the router is maybe 20 feet away. I even set up an additional Nest Cam and put it close to the doorbell during setup to help pair it. The latest code is NC022. Looked that up and says can't connect through bluetooth. Restarted my phone, scanned using bluetooth on it after and nothing was found. Any insight would be great, thank you!
08-11-2022 02:54 PM
Hey NCoviello,
NC022 error message means your camera couldn’t connect to your phone through Bluetooth. You’ll need to make sure Bluetooth is working and is enabled on your device.
Archie
08-19-2022 10:04 AM
Thank you for the clarification! Have you had the chance to go through any of the troubleshooting that @aatienza suggested?
08-19-2022 11:41 AM
Yes, I've tried with 3 separate phones and each time gets stuck at the same place.
08-19-2022 11:47 AM
I see. So sorry to hear that you are still having this issue! I would suggest that you contact Support on this one. I believe they may be able to walk you through some additional troubleshooting steps, and they can even escalate the issue further if necessary.
08-19-2022 07:28 PM
Thank's for all your help in trying to solve this issue and to those who offered suggestions. I will take this up with support and hopefully that will do the trick.
Thanks again,
NCoviello
08-22-2022 11:08 PM
08-25-2022 11:20 PM
Hi NCoviello,
Checking in to see if you still need help with this. In case there are any follow up questions or comments. Please let me know if you need further assistance.
08-27-2022 03:18 PM
It's me again. We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you happen to have the same concern feel free to reach us out here or start a new thread.
08-16-2022 08:18 AM
Best regard,
08-17-2022 08:45 AM
Just checking in on this thread and the activity on it. We'll leave this topic open for another 24 hours in case there are any follow up questions or comments.
08-18-2022 07:30 AM
Sorry, I was unaware of the time restraints on these. No, everything that was mentioned hasn't worked. I've tried 3 different phones and still can't get past the bluetooth issue. Not sure where to go from here.
08-19-2022 08:59 AM
Have you tried to use the serial number or QR code to bypass that process and submit it manually?
08-19-2022 09:52 AM
I have used the QR code each time.
