Cannot mount Google battery doorbell after charging
Deanna
Extremely disappointed in the google battery doorbell.  Took off the doorbell to charge it.  I then tried to remount and it will not click into place and just falls off.  It looks like the release pin is stuck open.  Of course it is past the return period at the big box store I purchased it from and google store will only address items purchased from their store.  The doorbell is not even 60 days old and now completely useless.  After purchasing many Nest products, I cannot believe the mounting design would be so poor to fail after first charging.
BrianNest
This has happened to me as well on BOTH of my doorbells. Took them both off to charge for the first time and neither will click back into place.
I agree that the release seems to be stuck.
If anyone has figured out a way to release a stuck release please post here. infuriating.
GarrettDS
  1. Open the Google Home app
Google Home app
  1. .
  2. At the top right, tap your account.
  3. Tap Feedback
and then
  1. tap the type of device you'd like to submit feedback for.
  2. To display available emails, in the "From:" section, tap the arrow on the right. Select your email address.
  3. In the feedback summary, write a brief description of your issue.
  4. Be sure to check the box for Screenshot and System logs.
  5. To submit feedback, at the top right corner, tap Send
If you need anything else, please let me know.
Hey Folks.
