09-30-2021 01:02 PM
Got to the step where it tells me to press the button on my nest protect to help the doorbell connect to the network but then it keeps saying 'Try Moving Closer To Another Nest Device' .. everything is on the same wi-fi. I keep pressing 'try again' with no success. Tried moving close to the protect, also tried going close to the nest thermostat but it won't work. Any ideas?!
Solved! Go to Solution.
10-04-2021 09:10 AM
So.. after many hours of trying everything, the ONLY thing that worked was using my wifes iphone to install google home and then created a new home... nothing else worked. I just moved my google mini speaker into that home so the doorbell works now.
09-30-2021 01:28 PM
Having the same issue with wired doorbell.
10-04-2021 09:06 AM
Following as I have the same issue with both the wireless doorbell and camera I recently purchased. All other troubleshooting steps have been followed with multiple router and phone restarts, but no luck getting them to connect.
10-04-2021 09:10 AM
