06-14-2023 04:07 PM
I changed routers and now have a new Wifi password. I am unable to change my wifi password on my google cameras. The instructions say I should use the Googlehome app but that ability is not found there. Anyone know how to do this?
06-14-2023 04:43 PM
I'm not sure what instructions you're looking at, but you can't use the Google Home app to change the Wi-Fi password for ANY Google Nest cameras.
Since Google Nest does not make it easy to change Wi-Fi settings on most of its devices, their first recommendation when getting a new router/modem is to set the network name (SSID) and password to the same values used on your old router/modem. That's what we did when we got a new router/modem, and we didn't have to update any of our Google Nest devices.
06-15-2023 07:53 AM
Thanks for response. I had no choice. Comcast insisted that I change my wifi password. I have had no problem with new password except for my two Nest cameras.
06-15-2023 08:57 AM
We have Comcast and were able to change Comcast's default SSID and password to values of our own choosing.
If you cannot change them, see the link I provided earlier for Google Nest's recommendations for how to change Wi-Fi settings.
06-15-2023 11:25 AM
Thanks again. I could keep my SSID but had to change my password. The cameras are my only problem. I am going to try to disconnect their power and connect again so that they may be recognized as "new" and try that.
06-20-2023 09:42 AM
Thanks for reaching out. I'm sorry for the delay. I just want to check if you were able to proceed with the troubleshooting. Please let us know how it goes.
I appreciate your help, @MplsCustomer.
06-20-2023 10:13 AM
Thanks for asking. No methods using Nest or Google apps works. I have removed the cameras and cancelled my account. I have climbed up the side of my house and removed the easier accessed camera. I will now try to use my computer to directly attempt to activate this one.
06-21-2023 09:19 AM
Hey Brucecal,
That sounds like a plan! Please keep us posted. You can check out this link for additional reference.
06-25-2023 04:50 PM
It's me again! Checking if you still need help. Please let me know, as I'll be willing to assist you further.
06-26-2023 07:35 AM
I removed one camera (no small chore) and connected it to my computer. Using the proper applications, I was still unable to change the password and connect. I plan on removing the second camera when it cools down here in Texas. I will replace them with Wyze cameras (I have several).
Thanks for your help.
06-26-2023 09:39 AM
It's been hot up here in Minnesota too, though not as bad as Texas.
It's really unfortunate Google Nest makes it difficult to update Wi-Fi settings.
Is it possible for you to change your Comcast Wi-Fi password back to your previous password, so you can get your cameras back online?
07-06-2023 08:05 PM
Hey everyone,
@Brucecal, If you are using a 2nd Gen Nest Camera or Doorbell, in order to update the WiFi settings, you need to remove the cameras from the Google Home app and factory reset each camera. Here is a link on how to factory reset a Nest Camera or Doorbell.
Thanks for the help, @MplsCustomer and @Jenelyn_O.
Let me know if that works.
Edmond
07-09-2023 08:28 PM
I just wanted to follow up and see if the steps above work. Let me know if you have any additional questions from here.
Edmond
07-10-2023 08:47 PM
Hello there,
Please let me know if you have other questions or concerns as I will be locking this after 24 hours. Feel free to start a new thread and we'll be happy to help.
Edmond
