03-03-2023 05:39 PM
Setting up nest doorbell (battery) when I try to connect to my home wifi network it says something went wrong 'no internet connectivity on this network' which clearly the is as all other devices are connected and working fine. Tried multiple times, now it doesn't even get as far showing me the networks to choose from, it just goes straight to 'We couldn't connect to that network. Check your password'. Pulling my hair out.
03-08-2023 09:25 AM - edited 03-08-2023 02:55 PM
Thanks for bringing this up to me, I'd love to take a look into this for you. The first troubleshooting step that I'd recommend would be to restart your device. This process should keep all your settings, and reconnect it to the same Wi-Fi network. This might be helpful if it ever freezes, has connection problems, or isn't working normally.
03-11-2023 07:53 PM
Hi bernytbolt,
Checking in — did you get a chance to restart your camera as suggested by Brad? If so, how did it go? Let us know if you need more help.
I appreciate your help, Brad.
03-12-2023 09:01 PM
