09-04-2022 03:32 AM
Something went wrong error. Can you please advise how to resolve this error? We have tried rebooting the doorbell and also turning aeroplane mode on and off on our Google App device that is trying to make the connection to the doorbell, however neither worked to resolve the issue. Further, no other trouble shooting options have been provided. Please help
09-08-2022 12:58 PM
i am having this same exact issue! its been a month now!! google has no soltuions and no fix....smh....i am still waiting for them to get back to me but they keep closing out the forums of everyone who is posting about this issue
09-09-2022 10:19 AM
I am terribly sorry to hear that you're having this issue with your Nest camera! I'm sure it's frustrating, but I'm happy to look into this and see how we can help out. The first troubleshooting step that I'd recommend would be to restart your device. By doing this, it should keep all your settings, and reconnect it to the same Wi-Fi network. This is helpful if it ever freezes, has connection problems, or isn't working normally.
09-12-2022 12:03 PM
Just checking in to see how the conversation is going, as there's been a lapse in activity on this thread.
09-13-2022 05:28 AM
Hi Brad
Thank you for the suggestion. I have tried restarting the device however have received the same error message. Are you please able to advise an alternative suggestion to resolve this issue?
Thanks
09-13-2022 11:11 AM
they literally give the same reply to everyone posting about this but still no fix! it’s been a month and my doorbell still won’t connect to the app
09-13-2022 10:29 PM - edited 09-13-2022 10:32 PM
Thanks for your help here, Brad.
I'm sorry to hear that your Nest Doorbell (battery) can't be paired to your Google Home app. No worries, we'll sort this out. A few questions: what's the status light of your Nest doorbell? How far is your doorbell from the router? Do you have an Android or iPhone? Also, what WiFi frequency band do you try to connect to (2.4 GHz or 5 GHz)?
Give these steps a try:
Let us know how it goes.
09-19-2022 06:19 PM
It's me again. I want to make sure you're all good — how did the steps go?
09-20-2022 06:27 PM
I just wanted to jump in here to make sure that you saw my response. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
09-20-2022 08:00 PM
Hi Jt
thank you for following up. I have not yet had an opportunity to try these steps. Once I have had a chance to do so I will let you know if this helps to resolve the issue.
thanks
09-20-2022 11:01 PM
Hey MRK,
Cool, sounds like a plan! Keep us posted.
09-21-2022 10:39 AM
i have tried all these steps already still no luck…..can we have this escalated to corporate? again it looks like there are many of us who have this issue
09-24-2022 05:21 PM
Thanks for trying the troubleshooting steps. You can also give these steps a try:
Let me know how it goes.
09-27-2022 08:26 PM
Checking back in should you still have further questions here. Let us know by replying to this thread.
09-28-2022 08:37 PM
09-28-2022 10:04 PM
Hi JT
I have been travelling so have not yet had an opportunity to try the above suggested troubleshooting. I will be able to try this within the next week so will let you know how I go and if the issue is resolved.
Thanks and regards
M
10-01-2022 05:27 PM
Hey MRK,
Got it, thanks for following up. Sounds like a plan! We'll keep this thread open.
Keep us posted.
10-04-2022 06:38 PM
Checking back in — did you get a chance to try the steps I shared above? If so, how did it go?
10-05-2022 06:07 PM
Hi JT
I have tried your suggested solution however it did not work. I have reached exactly the same error screen ('Something went wrong...etc') that I have shared via screenshot in my first post on this thread. Are you please able advise another solution to resolve this issue?
Thanks
M
10-05-2022 06:26 PM
Hey MRK,
I truly appreciate your efforts here. You can also give these steps a try:
Let me know if that helps.
10-05-2022 06:42 PM
Also in addition, I have just tried to connect a Google nest mini to the new Home. It worked perfectly, which suggests the issue is with the doorbell. Please suggest a solution?
10-08-2022 11:00 PM
Got it, I shared some steps above that should help do the trick. Those should help you get back on track.
Let me if you need more help.
10-11-2022 11:16 PM
Hey MRK,
How's it going? Still need our help?
10-12-2022 02:18 PM
Hi JT
i am having some difficulty with step 2 above. Please give me some time to work that out and then I will let you know if this process has resolved the issue
thanks
m
10-12-2022 03:28 PM
Hello MRK,
Sure thing — take your time. We'll wait for your update here.
Thanks for the help, JT and Brad.
Jennifer
10-15-2022 03:59 PM
It's us again. We don't want to be a nudge but we'd like to check if you were able to try the step. Don't hesitate to reach back should you still need help.
Jennifer
10-16-2022 08:16 PM
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you happen to have the same concern feel free to reach us out here or start a new thread.
Thanks for chiming in, Jennifer.
