Disconnected my camera and trying to reconnect
Helpmewithstuff
I disconnected my nest cam from Google Home and I am trying to reconnect it and it says it’s still connected to my account and won’t allow me to reconnect please help.
17 REPLIES 17
@Helpmewithstuff
When you say you "disconnected my nest cam from Google Home", what exactly did you do and why, and is your camera the new Nest Cam Indoor camera (https://store.google.com/product/nest_cam_indoor?hl=en-US)?
I was traveling and wanted to take it with me and set it up on a different Wi-Fi. I couldn’t get it to set up and I read that I should remove the device from my Google Home which is what I did. But I still couldn’t get it to connect. Anyway now I’m back in my original location with the prior wifi that it had before and I’m trying to connect the camera and it says that it’s needs to be disconnected from my Google profile but I already did disconnect it so I’m not sure where to go from there or how to set it back up ?
As far as the camera goes it must be the version right before that one on the link you sent because it doesn’t have those two little dots above the lens
@Helpmewithstuff
Google Nest does not make it easy to change Wi-Fi networks on most of its Google Nest devices. The process is to remove the Google Nest device from the Google Nest app or Google Home app while you are on the original Wi-Fi network, then do a factory reset if it did not occur automatically, and then re-install while on the new Wi-Fi network.
I'm not sure exactly all that transpired in your case, but if you removed it from the Google Home app after you had left home and were not on your home's Wi-Fi, then the camera would have been offline and the automatic factory reset would not have occurred.
You could try doing a manual factory reset and then try re-installing. Depending on exactly what happened with your camera, that might work.
https://support.google.com/googlenest/answer/9223711?hl=en#zippy=%2Cuse-the-google-home-app
Thank you. How do I do a factory reset?
The camera is not listed on my Google Home anymore so not sure how to reset it?
@Helpmewithstuff
The instructions in the link I shared above has a link on how to do a factory reset manually.  Here is that link:
https://support.google.com/googlenest/answer/9252162#factory-reset
Thank you I’ll try this now and let you know if it works. Appreciate this!
Thank you for your help, MplsCustomer!
Hi sorry I will be trying this tonight. I haven’t had free time to do it. Thank you
@Helpmewithstuff
Glad to hear you are going to go through those steps. Please let me know if I can provide you with any assistance.
@Helpmewithstuff just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, I would be happy to keep it open. If there's more we can do, just let me know.
I appreciate your help, Brad and MplsCustomer.
Helpmewithstuff
Hey I tired the link but I don’t see where it says how to perform a factory reset. It just just explains what the factory reset does .
Helpmewithstuff
Actually I found out how to do it and fixed it. Thank you
Hey Helpmewithstuff,
Sounds great! We’re glad to hear that. As we got our resolution here, I'm going to mark this thread as resolved. I'll be locking this thread if we won't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Thanks for the help here,  MplsCustomer and Emerson.
