Doorbell Audio echoing
SD10001
I recently purchased and installed the Nest Hello, however when visitors speak into it, they will hear their words spoken back to them.  AKA it is echoing their voice so it makes conversations very difficult.  Sounds like maybe this is an issue between the Google/Nest app and Samsung phones?  I am using a Samsung S9+. The unit does not exhibit these problems using my IPAD. Has anyone found a resolution for this or know if Google is working on a solution?
giugio
hello, I have the same problem with my galaxy A71.
have you find a soltion to the problem?
Just checking in to see if you still need assistance with this issue.  We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
Hey Folks.
