Doorbell battery and Google assistant enabled third party speakers
codemedic
Would the doorbell battery version be able to do announcements or ringing on a Google Assistant enabled third party speaker?
Like many, I had the late realisation that the device does not work with a standard UK wired doorbell ringer. So I am looking for an alternative that is easier on my wallet.
Thanks
janthadeus
Hi codemedic,
While we can’t recommend third party devices as they may or may not work. Have a look at this guide and let me know if you have more questions in mind: Set up your Google Nest or Home speaker or display
janthadeus
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
codemedic
I am sorted for now. Thanks.
It turned out that my wired doorbell had a faulty relay contact. My preferred option was the wired doorbell, and that is now working.
janthadeus
Happy to hear that! I appreciate the gesture. It looks like we can consider this one complete, so I will be locking this in 24 hours if we won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
